Code
import requests
import urllib3
urllib3.disable_warnings()
response = requests.get(url, verify=False) # Disable SSL verification
response.raise_for_status() # Raise an error for bad status codes
return response.json()
# Printing the data
uniprot_id = "P09958"
display_uniprot_data(data)UniProt ID: P09958
Protein Name: Furin
Organism: Homo sapiens
Function: Ubiquitous endoprotease within constitutive secretory pathways capable of cleavage at the RX(K/R)R consensus motif (PubMed:11799113, PubMed:1629222, PubMed:1713771, PubMed:2251280, PubMed:24666235, PubMed:25974265, PubMed:7592877, PubMed:7690548, PubMed:9130696). Mediates processing of TGFB1, an essential step in TGF-beta-1 activation (PubMed:7737999). Converts through proteolytic cleavage the non-functional Brain natriuretic factor prohormone into its active hormone BNP(1-32) (PubMed:20489134, PubMed:21763278). By mediating processing of accessory subunit ATP6AP1/Ac45 of the V-ATPase, regulates the acidification of dense-core secretory granules in islets of Langerhans cells (By similarity)
