Code
import requests
import urllib3
urllib3.disable_warnings()
response = requests.get(url, verify=False) # Disable SSL verification
response.raise_for_status() # Raise an error for bad status codes
return response.json()
# Printing the data
uniprot_id = "P38567"
display_uniprot_data(data)UniProt ID: P38567
Protein Name: Hyaluronidase PH-20
Organism: Homo sapiens
Function: Involved in sperm-egg adhesion. Upon fertilization sperm must first penetrate a layer of cumulus cells that surrounds the egg before reaching the zona pellucida. The cumulus cells are embedded in a matrix containing hyaluronic acid which is formed prior to ovulation. This protein aids in penetrating the layer of cumulus cells by digesting hyaluronic acid
