Code
import requests
import urllib3
urllib3.disable_warnings()
= f"https://rest.uniprot.org/uniprotkb/{uniprot_id}.json"
url = requests.get(url, verify=False) # Disable SSL verification
response # Raise an error for bad status codes
response.raise_for_status() return response.json()
= data.get('primaryAccession', 'N/A')
primary_accession = data.get('proteinDescription', {}).get('recommendedName', {}).get('fullName', {}).get('value', 'N/A')
protein_name = data.get('gene', [{'geneName': {'value': 'N/A'}}])[0]['geneName']['value']
gene_name = data.get('organism', {}).get('scientificName', 'N/A')
organism
= next((comment for comment in data.get('comments', []) if comment['commentType'] == "FUNCTION"), None)
function_comment = function_comment['texts'][0]['value'] if function_comment else 'N/A'
function
# Printing the data
= "P01833"
uniprot_id = fetch_uniprot_data(uniprot_id)
data display_uniprot_data(data)
UniProt ID: P01833
Protein Name: Polymeric immunoglobulin receptor
Organism: Homo sapiens
Function: Mediates selective transcytosis of polymeric IgA and IgM across mucosal epithelial cells. Binds polymeric IgA and IgM at the basolateral surface of epithelial cells. The complex is then transported across the cell to be secreted at the apical surface. During this process, a cleavage occurs that separates the extracellular (known as the secretory component) from the transmembrane segment
