Code
import requests
import urllib3
urllib3.disable_warnings()
response = requests.get(url, verify=False) # Disable SSL verification
response.raise_for_status() # Raise an error for bad status codes
return response.json()
# Printing the data
uniprot_id = "P08887"
display_uniprot_data(data)UniProt ID: P08887
Protein Name: Interleukin-6 receptor subunit alpha
Organism: Homo sapiens
Function: Part of the receptor for interleukin 6. Binds to IL6 with low affinity, but does not transduce a signal (PubMed:28265003). Signal activation necessitate an association with IL6ST. Activation leads to the regulation of the immune response, acute-phase reactions and hematopoiesis (PubMed:30995492, PubMed:31235509). The interaction with membrane-bound IL6R and IL6ST stimulates 'classic signaling', the restricted expression of the IL6R limits classic IL6 signaling to only a few tissues such as the liver and some cells of the immune system. Whereas the binding of IL6 and soluble IL6R to IL6ST stimulates 'trans-signaling'. Alternatively, 'cluster signaling' occurs when membrane-bound IL6:IL6R complexes on transmitter cells activate IL6ST receptors on neighboring receiver cells (Probable)
